Looking for $18000 or best offer.
Look, ask questions, make reasonable offer, NO lowballs.
Located outside Knoxville, TN.
1989 944 S2 is powered by a 3L four-cylinder engine paired with a 5-speed manual Limited Slip transmission, delivering a thrilling driving experience. Equipped with Brembo 4 Piston, four-wheel disc brakes, power steering, fuel injection, and a single exhaust outlet, this Porsche offers premium performance on the road. The iconic design elements of the German classic include VDO instrumentation, rear spoiler wing, side marker lights, pop-up headlights, front fog lights, and a rear window defroster, showcasing the timeless appeal of this classic sports car.
Adding to the special attraction are the 16x7, 16x8 -inch Design 90 style wheels, which perfectly complement the sleek lines and aerodynamic profile of this 944 S2. The alloy wheels not only enhance the vehicle's visual appeal but contribute to its overall performance and handling. Enhancing both style and functionality, this classic car comes fitted with a range of convenience features. Enjoy the comfort of air conditioning, a Boss Audio touchscreen stereo, power windows, power mirrors, power locks, removable power moon roof, cruise control, air conditioning, courtesy lights, original digital clock/stopwatch, a glove box, and sun visors with vanity mirrors
This example has had extensive maintenance and special touches that make it an exceptional car in great condition and needs nothing but to be enjoyed and driven.
5 speed manual limited slip (083F - AOT)
Moon Roof
Cruise
A/C
Power Windows
Power Locks
Power Mirrors
Touch Screen Boss Audio BE920WCPA-C Radio with Apple Play and Android Car, back up camera.
(Original Blaupunkt Radio and Equalizer included)
Maintenance:
New Bilstein Sport Shocks
All new Powerflex Bushings
All new Wheel Bearings
New Only 944 led headlamp conversion kit
New lower A arms with new ball joints.
Rebuilt original Steering Rack
New power steering reservoir
New power steering belt
New A/C belt
New coolant tank
All new red silicon water and vacuum lines and stainless band clamps
New radiator bushings
Resurface Flywheel
New Crank Position sensor
New Clutch, Pressure Plate and Throw-out Bearing
New Torque Tube Bearings
Rebuilt Original 5 spd manual limited slip (083F - AOT)
New Synchros, Bearings, Seals, (OEM Porsche)
New LSD Clutches and Plates
Only 944 Shifter and Short Shift kit.
Spare manual trans included, used while rebuilding original.
New trans tunnel shifter sound absorber
New trans mount (urethane filled)
Refinished and rebuilt all Brembo calipers (non-scraper ring versions)
New brake pad sensors
New brake pads
New emergency brake shoes
New Stainless brake flex lines
New Cquence black zinc coated drilled and slotted brake rotors
New Batwing lower front splitter
New engine under tray
New engine belly pan
New oil cooler shroud
New manifold back Cargraphic full exhaust system N-GT w/ converter replacement silencer.
New injector seals and tips.
New K&N Air filter
New AOS Seals
New Cam tensioner pad
Timing belt service was done by PO just before I purchased it.
New camel interior carpet
New Tan leatherette racing seats (original seats provided)
New red seatbelt planet front seatbelts
New rear speakers
New power window switches
Speedometer gears replaced.
All interior lights converted to LED
New Fuel filler hose
New Fuel filter
New braided fuel lines front and rear
New Cam cover gasket
Red painted cam cover
New rear hatch seal
New rear hatch spoiler upper seal
New hatch lock bushings and seals
New rear hatch struts
New hood struts
New Titanium Lugnuts
Set of 17x9, 17x7-1/2 turbo twist wheels XXXXX
2 spare 17x9, turbo twist wheels
2 spare 16x8 D90 wheels
SOLD — 1989 Porsche 944 S2 For Sale
- IMG_2131.jpeg (3.22 MiB) Viewed 933 times
- IMG_2149.jpeg (5.46 MiB) Viewed 933 times
- IMG_2147.jpeg (5.01 MiB) Viewed 933 times
- IMG_2126.jpeg (7.22 MiB) Viewed 933 times
- IMG_2130.jpeg (6.56 MiB) Viewed 933 times
- IMG_2160.jpeg (4.32 MiB) Viewed 933 times
- IMG_2162.jpeg (5.08 MiB) Viewed 933 times
- IMG_2163.jpeg (6.14 MiB) Viewed 933 times
- IMG_2164.jpeg (2.24 MiB) Viewed 933 times
- IMG_2165.jpeg (3.19 MiB) Viewed 933 times
07turbeaux
- Has thanked: 10 times
- Been thanked: 7 times
What is with the seats? are those seat covers?
Nice looking car!.. good luck.
